Is it feasible to change the built-in IR-Cut filter/window on the ZWO ASI2600MC Pro for an AR window. I have an IR Pass filter I want to use for wide field, but the built-in IR-cut defeats its purpose. I had to replace the window on a 120mini that was broken. I've had no issues with it, but the 2600 is too expensive to gamble with.
Has anyone had experience with changing the window on the 2600 or similar camera?
Thanks!
