Hello! I'm having some issues with the setup listed in the title. Whenever I use the go home or go to feature from the ASIAIR, the GTI mount doesn't move anywhere close to it. It's also failing to accurately guide using my ASI120MM, resulting in blurry photos.
However I have no problem when using Go To function through the SynScan app.
I'd like to resolve this issue because I am unable to use guiding for longer exposures and I have to swap between the ASIAIR and SynScan app, complicating my work flow.
Any help is welcomed. Thank you!
