I have a CGX mount and use ASIAIR Pro to drive the mount. This configuration works great for the last 3 years.
Recently I got a AVX mount and tried to use the same ASIAIR Pro to drive the newly acquired AVX but had never been to able to connect to the mount from ASIAIR. The symptoms is: an error dialog is posted when try to connect to the AVX mount in ASIAIR.
Android phone message: "Connect Failed Please make sure the mount is connected to with the serial cable and the baud are correct"
iPad message: "Connection failed: Polar and 3-Stars align required and please update the HC FW to the newest version, or check the connection of the USB cable"
Based on various previous postings that addressed this similiar issue, here are what I had done:
- cable and baud: I verified the cable is not the problem. The cable works on ASIAIR to CGX and the baud is set to 9600.
- AVX mount: I also verified that using the same cable connecting to a mini-PC (Mele) and I can connect to and drive the AVX mount using NINA.
- Firmware: ASIAIR Pro is upgraded to 2.3.2(11.81)
NexStar+ hand controller is upgraded to 5.35.3179
Boot Loader is upgraded to 4.1.3160
AVX App is upgraded to 7.15.8270
I followed AstroBlender (as suggested in some thread) https://www.youtube.com/watch?v=8l4fiu4MTbk for the procedure to configure ASIAIR Pro to AVX. I can get all the other attached devices: ASI2600MC, ASI120MM, EAF connected and working EXCEPT the AVX mount.
I read that there may be some issue with the Prolific controller between AVX and ASIAIR Pro but this requires some sort of OS refresh, which I don't fully understand what it is and don't want to touch it unless it is absolutely necessary.
Can some kind soul help and point me to the right direction to take to get this configuration (ASIAIR Pro -> AVX) to work?
Thanks in advace.
