Hi there, I'm trying to build up a telescope system, which I'll be sending to a remote observatory in a few months. My system has four (!!) EAFs, as I have a primary telescope and a piggyback unit, each having an OAG and associated EAF. My problem is that the ZWO EAF driver in TheSky doesn't show the serial number for the currently selected focuser - only an ID from 0-3. This makes it very difficult for me to remotely verify that I'm connected to the correct focuser. It isn't clear whether the EAF ID is consistent between TheSky sessions, or if it will change depending on which USB port an EAF is attached to. Please can the ZWO devs add the serial numbers for the EAFs in TheSky's device selection dialog?
Please note that I'm using a Mac system, running TheSky via Rosetta. (I'm hoping that ZWO will one day release Apple Silicon versions of their drivers for the cameras, EAF, EFW and CAA)
