It would be great if we could set a custom Park position in the ASIAIR.
If this means also changing how the Home position is set that would be great, too.
Not being able to manually set the Home position is also a problem (currently, Home is set when you turn on the ASIAIR and enable connection to the Mount).
So, you could solve two things here:
- Allow for custom Park position
- Allow for Home position to be set manually instead of only at power up and mount connection.
