Sam,
Just following up.... I tried using your latest ASCOM driver (V1.0.1.20 ) and still see the same issue / bug where the exposure duration is different than requested. I'm able to work around this successfully by taking a second exposure with the same requested duration and discarding the first. So not a big deal for me, but would appear to make guiding a challenge since many software packages will take an initial exposure to select a star and then continue imaging with this exposure while guiding.... In this case your first image wouldn't be a good representation of what to expect. Let me know when this fix gets incorporated into an updated driver and I'd be happy to test. Thanks-
Tyler
From our previous discussion:
"Hi, I have tried your VBScript and the issue does exist, we will try to fix that, for you the fastest solution is discarding the first frame after changing the exposure time, which returns much shorter than the requested duration."
