Hello,
Since the last update, I can no longer stack the -subs again to eliminate satellite trails, for example. The final image is extremely noisy, and using denoising makes the result even worse.
It should be noted that the -sub images are extremely noisy.
Does anyone have any ideas on what I should do? My S50 is currently unusable.
Thank you for your help.
are my flat good enought?
