Support@Seestar
I explained this in V2.4.0, but I'll explain the framing bug in EQ Mode again.
I'm not a native English speaker, so I might not be able to explain it well, but I'll start from the basics. Do you understand horizontal coordinates and equatorial coordinates?
Horizontal coordinates: A coordinate system in which the horizon is at an altitude of 0 degrees and the zenith is at an altitude of 90 degrees.
Equatorial coordinates: A coordinate system in which the celestial equator is at a declination of 0 degrees and the celestial north pole is at a declination of +90 degrees.
In EQ Mode, equatorial coordinates are the basis.
When setting framing in SkyAtlas, the display and settings are done in equatorial coordinates.
However, there is a bug where when you start shooting, the image is taken with a rotation angle in horizontal coordinates, resulting in a different composition than in SkyAtlas.
I'm sorry, but I would like this bug to be fixed.
