advanced settings/eq mode and select "switch" to change back to alt-az. it will take your seestar to some home position during the change and you will then have to level your seestar like normal alt-az usage, removing the wedge piece and doing the leveling on the tripod or easier yet changing your wedge angle until the seestar leveling screen indicates you are level enough to do alt-az imaging.
