Function Optimization
Bug fixes
Hello,
Are the drivers compatible with Windows 11 ARM? Thank you.
Jean
Hi there Just downloaded this version ( ASIStudio_V1.15_x64_Setup ).
Any thoughts ?
JohnD
Is it possible to create a default to the SER video format? I much prefer SER -16 bit to the ASI 8 bit. I often forget to make that change. Otherwise ASI studio works well for Sun captures, and easier than other options. I use the Mac version. Thx
rrosenberg8 I will document your feedback. The current default setting is RAW8. I will submit your request to the R&D team. Thank you for your suggestion.
ZWO broke polar alignment in the june release.
