A question for ZWO staff or any plan gurus we have who are awake…
When using the plan function:
Two Scenarios:
If you have a Seestar in EQ mode, turn it on, hit execute on the plan and walk away, it will do the polar deviation initially before executing the plan yes?
If you have a Seestar in EQ mode and you turn it on, do the polar deviation, then close arm and hit execute but leave it turned on it will NOT need to do the deviation again before starting the plan yes?
I suppose the basic question is … please can you tell me what the sequence is when a Seestar in EQ mode has been turned on and execute has been turned on in the app.
Also in a remote scenarios - do you have any tips for mitigating cable wrap.
Thank you!
