can anyone explain what the "default gain" setting in plan mode does? when set to default does it use the gain setting programmed in the main camera tab OR is there some default setting of the gain that ZWO has chosen (example, for the ASI2600MC PRO, there is a gain setting of 100 where HCG mode is activated?)
If i set the gain to zero (0) in the camera tab does the "default" setting in plan mode use this value or revert to some ZWO selected value that ZWO considers a default value?
Thanks
