Is it possible to implement a mosaic generator for Seestar's EQ mode, in the same way as in ASIAIR, where you select a center point and the number of vertical and horizontal frames and the percentage of overlap between them? At the end, all you have to do is add the result to a new plan along with the amount of time in each of the configured frames. It would also be useful to be able to save these frames as a favorite object for future.
Exemple: Messier 8
Pane, RA, DEC, Position Angle (East), Pane width (arcmins), Pane height (arcmins), Overlap, Row, Column
Pane 1, 18hr 05' 14", -24º 15' 53", 359.00, 52.20, 39.00, 40%, 1, 1
Pane 2, 18hr 02' 56", -24º 16' 25", 359.00, 52.20, 39.00, 40%, 1, 2
Pane 3, 18hr 05' 15", -24º 39' 16", 359.00, 52.20, 39.00, 40%, 2, 1
Pane 4, 18hr 02' 57", -24º 39' 49", 359.00, 52.20, 39.00, 40%, 2, 2
