Can you suggest a recommended tablet to use with the Seestar S50. I understand GPS is required along with 2.4G/5.0G dual band WiFi as well as Bluetooth.
Gps isn't required, but with android you need a minimum of 6gb active ram. Get as much of active ram as you can.
I use a Samsung Galaxy A7 Lite with my S30 and a Samsung Galaxy A9+ with my S50. Both work well with the Seestars. Don
samsung s6 lite, works best with S50
I have the Galaxy Tab 8 (SM-X200) 10" and a newer 12" Galaxy Tab. I like the 10" better for using outside with the Seestar. I put a cover on it that has a hand strap on the back. It is much easier to hold and work with than the 12 ".
Many thanks for the suggestions. I have bought a Tab G6 from Doogee with 11" screen. Android 15. Operates the Seestar no problem. Has 6Gb RAM expandable 24Gb. Just need those dark skies.
I have 2 Samsung S9s for my S30 and S50. Work great.
