2.4.1 is an improvement but plate solves are still an issue. This is true using either method. Plate solves worked fine under previous versions, now it's hit or miss. Last night, even with more than 500 stars to solve on, the plate solve went on for more than a minute.. I bailed out and tried again and then it was almost instant. If I do a manual solve it almost always works, but if iI'm trying to get to a target it often fails. Hard to image under such a situation. Also, I used an older image to provide coordinates for an additional night of imaging, but the place the GOTO went was slightly off where the mount was pointing the night before. Again, a new problem I never had with older software.
