Hi, I've recently been having this problem, which I've attached in the images. I don't know if it's a transfer noise or intermittent noise. But I didn't have it before with the same setup. Everything goes through a USB hub, and it happens. But I repeat, it also happened before through the same hub and the same USB and power cable. In fact, if I connect it directly to the PC's USB port, this problem doesn't occur. I don't know what could be the cause.
Thanks, best regards.
