The ASIAIR Polar Alignment reduces resolution (see lower left), and uses less stars than in the actual field of view. For smaller sensors this can result in plate solve errors due to lower number of stars. Suggest using the full resolution of the sensor to Polar Align, don't reduced it. My 5x3 sensor gets constant plate solve errors with PA, because PA only uses a reduced view.
