I’ve been enjoying using the plan mode. However, I don’t like that I can’t edit the plan mode after I’ve started it and then stop it. Sometimes I need to stop it and make a change but in order to do that I have to make a copy of it. I also would like to be able to change exposure times per target. Sometimes in the middle of my plan, long after I’ve gone to bed, I’ve had a plan switch to a target near the celestial Pole. For that target, I may want the telescope to switch to 10 second exposures. The next item in the plan may be an easier target to use a longer exposure on. I would also like to be able to switch the plan timeline off of military time. I’m used to quickly reading 9 PM instead of 1900 :-) I also noticed that I can be shooting a particular object and the scope is dead aligned on it. But then when I execute a plan to go to the exact same object, it will be off center no matter what I do.It would be great to see these improvements made to this feature.
