2.4.1 was broken badly for me. I use a big scope - 3,000mm focal length - with ASI2600MC DUO, the field of view is a little under 0.5 degree.
Plate solving was totally broken (the OLD method worked fine). I had to use Preview mode and slew manually to a target.
Using AUTORUN on 1 target 30 subs x 180 secs, it would do a few subs then a hard crash requiring power-off-restart; basically unusable. Went home with maybe 10 subs total after 4 hours on the field.
Also it attempted a meridian flip at a totally stupid time with the scope approx 30 degrees from the meridian - I had to stop it manually to avoid crashing the scope and camera against the tripod.
OK I now have 2.4.9 and firmware 12.03 installed.
