I contine to have issue to polar alignement on EQ S50. Also, after correct parameters, if you refresh parameters return to bad conditions.
Next release there will be some improvements for EQ polar alignement ?
Thank Giuseppe per
To better understand the issue with your polar alignment on the EQ S50, could you please upload a video of the operation you’re performing using this link: https://support.zwoastro.com/? This will help us analyze the issue more effectively.
