Hi ZWO, Any chance of combining two of your products to create a Sony emount 5mm tilter plate? Allowing the use of sony lenses on your 90mm cameras. As the back focus on the sony lens is 18mm and the 90mm zwo cameras having a back focus distance of 17.5mm, the adapter needs to be inside the 5mm tilter plate. It would be nice to use the 17.5mm to make sure you can adjust the tilt and still achieve infinity focus. I'm more than happy to test any prototypes 🙂
Thank you, and I hope you consider this suggestion.
