I have two AM5 mounts which I use for both imaging and visual observations. One feature that I think would be a wonderful addition to the ASIAIR would be the capability to import observing lists.
As an example of what could be done, SkySafari allows important of target lists using a special file format called skylist. There is an archive of skylist files:
https://www.skysafariastronomy.com/repositories/index.php?dir=skylist&theme=onyx
The Nexus digital setting circles which I use with a manual alt/az mount all allows importation of skylist file.
