After my most recent mount firmware update, the home position seems to be off by 180 degrees. When I issue a go home command, ( from my ASI Air software or via SkyAtlas )the mount swings so that the saddle is down and the counterweights are up.
I stripped the mount of all accessories and let it invert itself, after which I entered the calibration routine. But when I do this, the system tells me that the calibration failed because the mount is more than 5 degrees off the starting position.
Any and all help appreciated
john
