I would like to switch from 174 mini to 585mm mini for guiding with OAG. Is there a plan to introduce the 585mm in mini format?
I would like to be able to insert the guide sensor into the OAG guide port so it is closer to the prism and has a wider view of the pupil. This will allow it to collect more light, vs. having it farther from the pupil.
There are competing versions of the 585mm in mini format, but I would prefer to stick to ZWO - so it would be great if a mini version could be offered.
Thanks,
Frank
