Dear @Tech@ZWO,
I recently purchased an ASI585MC Air and am currently waiting to receive it. In the meantime, I've been studying the camera’s gain settings and I have a few concerns I’d like to clarify.
Specifically, I noticed that at the HCG (High Conversion Gain) value of 252, the Full Well Capacity is slightly below 2ke⁻. This worries me a bit, as I fear it may limit exposure times to avoid star saturation. On the other hand, using a lower gain, such as 50, results in a much higher Full Well Capacity (over 20ke⁻) and dynamic range, but with a significantly higher readout noise of around 5.5 e⁻ RMS.
How should I approach gain selection for deep-sky imaging with this camera? Are there any recommended exposure times based on gain values and their corresponding readout noise?
Before making the purchase, I was very excited about the ASI585MC Air, but after carefully analyzing the gain charts, I’m now a bit concerned about optimizing the settings for best results.
Lastly, may I suggest adding the ability to manually set the offset value from within ASIAIR? It’s such an important parameter, and including it—even in an advanced settings section—would be very helpful, even for users who rely on the simplified 1-2-3 setup process.
Thank you in advance for your help and support. I’m looking forward to your reply.
Best regards,
Paolo
