Lilo
I think you're completely misunderstanding something in this picture.
Let me try to explain how I do it in my own words (and it works very well).
EQ mode --> you set your latitude to 51°. A green checkmark appears.
Get Polar Align
Now you only need to look at the top two values! Not the
51° (or the deviation!!)
You just need to bring the top two values to zero (or
almost zero).
When the green checkmark appears, you're done.
Under no circumstances should you try to set the 51° again.
This is how it works for me, and it makes perfect sense, since the initial 51° setting is based solely on latitude.
In Get Polar Align mode, a more precise alignment is performed using three different stars.
Therefore, in this mode, the degree value of 51° (in your case) should be ignored, and only the two upper values should be considered and ideally set to zero.
Regards, Michael
