Lilo
First thank you very much for replying here. It was an AI response in google.
Seestar s50 lights do not turn blue or go off after fully charged:
“ If your Seestar S50's charging lights are not turning blue or off after a full charge, it indicates a potential issue with the charging system or battery management. The device may be stuck in a charging loop or experiencing a battery temperature issue. You should try different troubleshooting steps like checking the cable connection, trying different cables and power sources, and ensuring the device is at a suitable temperature for charging.”
Now going back again and reading through, I now might think without being specific, later in the response it does talk about battery temperature, but never specifically spelling out that this is an issue.??
Amongst several possible causes they have one paragraph that references temperature:
“ Temperature Issues:
The Seestar S50 has temperature sensor that might prevent charging if the battery is too cold or too hot.”
But, this is only one possible cause.
Never believe everything you read, and never ambiguously interpret things without more knowledge!
Thank you to you and ZWO support for responding to my concern.
