Various discussions from ZWO here and on Facebook indicate that only the ASIAIR 256G (no SD card slot) version has Bluetooth. However the EAF PRO documentation says that it will work with devices with IC codes ending in ASIAIRPLUS. I have a 32G device with that IC code. Both the EAF and mount settings show a BT option. Will it work with the EAF PRO over Bluetooth?
