Ryo0kami3 Seestar can't track comets or asteroids.
返信ありがとうございます。 C2023-A3では、15分でも気にならなかったので 追尾しているものと思っていました。 彗星の動きによって写り方も変わるのですね。 希望ですが彗星を追尾する機能は 追加できないものでしょうか? ありがとうございます。
Ryo0kami3 Because A3 was slow I think. You can use external software like Siril, ASTAP to stack on comet. You can see some on my page. https://www.astroimg.com/user/552791209915977731?locale=en&shareUserId=552791209915977731&shareId=1755743477853
The 4k mode saves the fit files in 4k also?
Individual subs are saved as native 2k from sensor, but stacked file is 4k, including the fits stack.
talktogreg You sure about that? I don't believe the FITS file is scaled up (down??). Have you reviewed the master fits file header to determine if 4K resampling was performed on it? I was under the impression the resulting JPG file is upscaled but the FITS file is untouched.
marvindj You are correct. Ignore my comment/question....
App 2.6.1, fw 5.50 Whats new?
eaJ2Wyht No new features were released in V2.6.1.
Support@Seestar So something must have changed. Hopefully, you haven't just changed the application and firmware version numbers. 🙂
eaJ2Wyht
Support@Seestar #4 What are those bugs?
[unknown] Why do you want to know? ;-)
I dont use seestar from 3-4 months Now i ear a different sound from gears, its because of the new firmware?
satch984 Yes, it is expected with the new firmware.
