When creating a plan, you select an object such as M 31, and the name appears in the screen, and later, once the plan execute, in the filename. However, if you pick an item from your favorites for your plan, it brings up the item as "Unknown", and you have to edit the name of the object on the plan screen. If you don't, the files will be saved as "Stacked#Unknown.... It would be great if the file was named as the same name as the Favorite, instead of having to re-enter it again on the plan screen.
Thank you,
Scott
