Can you connect the 2600MCAIR to the AM5's wifi for mount control?
I have tried a couple of times, used the IP address in the AM5 hand controller but it doesn't seem to connect.
SteveD If you want to enable the Wi-Fi function of am5, please follow the instructions to access the hand controller and connect. The old AM series does not have Bluetooth function, which is a new feature of AM3N and AM5N.
I don't think this will work, I use bluetooth and it works fine
The AM5 doesn't have bluetooth as I recall, just the AM5N and AM3 and 3N. But no, you can't connect as requested.
