Latest app and fw. Seestar is connected to PC by USB. USB storage is mounted, Ok. Now start the app on phone. Looks good, only recharge, Ok. But stop!! After clicking that button seestar disconnects from PC. USB storage disappears. Why?
The button says ’Only recharge’. When you click it you are saying that the only thing you want to do is recharge the Seestar from your PC. You only see the message on your Seestar app when you are connected to the Seestar from the app and the Seestar is also plugged into a PC. I think it’s because the developers don’t want users potentially modifying files/folders from 2 devices (PC and Tablet/Phone) at the same time. This is unchanged in the last few versions, I can’t remember when it wasn’t like this.
Ok, I see now.
This indicates that you are currently connected to the computer and Seestar via a USB cable for data transfer. If you tap "Only recharge" on your phone screen, it means you are only using the USB cable to charge the Seestar from the computer.
