Tech@ZWO
Good Morning, I have not done the modification belt for the moment. I want to characterize the mount behavior before and after the modification. Under Windows, with PHD2, I could disconnect the guiding orders send to the mount in order to characterize the mount. Could I characterise my mount with the Asiair? I see two possible solutions;
1) disconnect the USB cable between the Asiair & the mount
2) set the RA & DEC agressivity to zero in order to avoid guiding command towards the mount
I have verified my mount. In June, I have update the firmware of the mount because I receive a request message.
I have the 1.5.6 version, could you post the 1.5.1 firmware version in order to come back before the update.
I try to make a "report" in order to help you in your investigations & solutions.
Thank you for your help
