I have the following issue with ASIAir 2.4.1 (10.93): The EAF shows current position 0 and Limit 0. Both figures cannot be set, especially the Limit (e.g. to 60'000). As soon as I enter a number and confirm, it goes back to 0. As soon as I start autofocus, I get the following message: "EAF abnormal ensure current position is away from 0 and max step limit so the EAF is movable". I updated the firmware of the EAF to the newest version 3.3.8 but it's not helping. My Hardware is a ASIAir older version, in the white/pink case. If I try the same procedure with ASI Studio on the PC, everything works, the Limit can be set. Any ideas if it's a bug in the ASIAir software or if I'm doing something wrong?
