At the moment there isn’t a plan to add a switch during the capture process to disable drizzling.
By default drizzling is turned off when starting a new session — it only activates when you manually enable it before imaging.
So as long as you don’t turn it on at the beginning, drizzling will stay disabled for the whole session.
