Morning,
Thanks for the feedback, I've now tested/followed all those options.
1.Try stretching the option box -
The box will not be stretched in any direction (the cursor doesn't change). Additionally, the drop-down menu doesn't allow you to maximise/minimise the window; however, the window does change if you adjust the zoom percentage.
2.Uninstall the ASCOM driver and reinstall the latest version
I completed this by updating the Ascom platform to version 7, deleting and reinstalling all Ascom drivers, and checking and resetting all the associated ports and settings required to reconnect everything. However, I did see that with the new Ascom, I can see the EAF controls and settings in the Ascom settings.
3.Test the EAF connection in ASIStudio to check if it can be enabled
Yes, I can check and change the setting in the ASI Studio - a good work, and this Thursday (clear skies, fingers crossed) I will try running an AF profile.
None of this helped with the strange situation of that settings box in NINA performing very strangely.
