Hello
I have a problem with my Asiair Pro in conjunction with a Skywatcher Wave 100i.
When using the Skywatcher app, the saddle in the home position is perfectly parallel to the mount body. When using the mount with my Asiair, the home position deviates about 3 degrees from the optimal position.
Can I set an offset in Asiair for the deviation in the home position?
Greetings from Bavaria
Walter
