We currently do not have flat panel development in progress, but I will relay this feedback to our R&D team. If you need to use Wanderer Astro flat panels without repeatedly cycling the power port, you can manage the power supply via ASIAir. As long as you do not manually turn off the power output on ASIAir, the power will remain on.
