Last night I ran an S50 imaging session using the Framing mode. I tried to select the LP filter option, but, all the images used the IRCUT filter. How do I select the LP filter when using the Framing mode?
Steve
WC0ZSm8I "Execute Enhancement after goto" is turned on, right? Try to turn it off. Then you'll be able to select LP filter and start the session manually. But be ready to get in correct frame rotation )))
Hi Steve, first enter Stargazing Mode without selecting a target. Then switch on the LP filter. After that, open Sky Atlas from the bottom-right corner, choose your target for framing, and tap Goto to start imaging.
Support@Seestar
It worked! Thank you for the help.
