Hi Gordon,
Yes, there are currently two ways to export files from Seestar to a computer:
1.Connect Seestar to your computer via the Type-C port after powering it on, and simply copy the files.
2.In Seestar Wi-Fi settings, connect it to your home network. You can then access Seestar’s storage via its IP address and copy the files you need. https://h5.seestar.com/course/79218
Additionally, in Stargazing Mode, you can manually enable “Save each Frames” in Advanced Features. Once enabled, quality frames during stacking will automatically be saved in FITS format in the Seestar album.
