Hello, last month I splurged and purchased an ASIAIR Plus, AM5N mount, 220mini, and OAG. I set this all up with my FSQ106 and EAF that I already had and was blown away with the ease of use of this setup. The only issue I can see with this is that my DC 12V Output 4 will not enable. It is not a show stopper and I was just amazed with the results and plan to use this as my portable rig.
In fact I was so impressed with the system that I went ahead and purchased another ASIAIR Plus, EAF, OAG, and 220mini that I planned to integrate on to my AP1100GTO mount that currently has my TEC-140 mounted on it. Just to validate all is working well and to see if the 12v DC Output on port 4 is an equipment issue I replaced the first ASIAIR Plus with the new one. Like the original unit, it did the firmware update and I have no problems connecting to it with my IPad with the WIFI. However, with the exact same cable configuration that the first unit uses (in which the AM5N mount, EAF, 220mini, and 2600MC all connect) the new unit only detects the EAF that is powered through the USB connection. I am unable to enable the power for either the mount or the camera (the DC Output ports on the wifi tab will not enable (turn green). On the mount tab I can enable the connection but nothing occurs (because no power?). During the initial power up of the unit the DC ports are enabled and the camera and mount turn on, then when the AISAIR finishes booting they turn off. I have already removed and reloaded the firmware with no change. When I plug in my original ASIAIR Plus back in everything works just fine.
Am I just missing something obvious?
Thank you for any advice!
Jerry
