I put an evening's imaging session onto a Samsung USB flash drive (which is connected to the ASIAir Plus) instead of sending it to the eMMC. The app shows the data is indeed on the flash drive, but when I then remove the drive from the ASIAir and plug it into a PC, the PC shows the drive to be empty. I've tried two different PCs and several different USB ports...same result. And the PCs say the USB drive is operating correctly.
1) Any thoughts on what's happening?
2) How might I transfer the USB data back to the eMMC so as to retrieve it?
Thanks. JR
