Corsair I have a PC connected to it already, that's not an issue. What I wanted to do is simplify a little and remove a dedicated guider from the setup as it makes switching from my Edge 9.25 to the Rasa 8 easier. The idea of a Main Camera and guide camera all in one just appealed to me. The the built in air is just an extra if you will. A poor do on my part for not fully researching if there were any issues with connection. The lack of proper documentation should have been a red flag, but alas...
The main issue is that the ALPACA connection is rather hit and miss, and the slow speed of it is what's causing bottlenecks in the system, causing camera timeouts, hence why I'm open to using the "air " function. Pity that you can't just have everything run off the USB cable.
@Tech@ZWO any wisdom you can throw this way or the thread that I started on this a couple of days ago?
