Hi, I have some suggestions to improve the AI Denoise function:
Recognizing and removing ugly image edges affected by the field rotation in AZ mode. Presently it is not done by AI Denoise, it is even highlighted and more visible after AI Denoise.
Recognizing and removing satellite or aircraft trails. This would be a very important and welcome feature since there are going to be even more and more satellites and some objects will be impossible to shoot due the satellite trails. (Now I always do a simulation with Stellarium to see if the planned period will be affected by satellites and sometimes there would be more than 13 satellites in 10 minutes passing through the field of view.)
Selectivity. AI Denoise does not seem to be selective for different image issues, apparently it does the same for all images, just blurring the whole image to remove background noise.
Thank you in advance.
