Bit of an odd one. Using the mini the images write perfectly fine when using the unit itself and controlling via the android app (autorun, plan or video mode), using images management within the app you can also see and open all written files.
But when usb c (asiair mini output) connected to a PC, the files aren't there. I have to WiFi connect to the unit and then type in //asiair to connect, into emmc then the files are there. I don't see how this can be any other issue other than a hardware one.
Is there a solution?
On a side note I also have phantom folders present, they were deleted via the app many moons ago using the clean button on the next following session but when pc connected they reappear. No amount of deleting or clearing gets rid of them. Yet another symptom of a hardware failure?
