JWRI97 If the moon is out I’d go to it and check upper atmosphere winds by seeing if the view has wavering from winds. There is also I’ve been bothered by high light clouds that aren’t visible but sometimes give it away when seeing a red tinge that shouldn’t be there. That’s typically for me eitherclouds or VOG from a volcano. Since figuring is done on the scope I can’t see it as a WiFi interference but there could be a possibly logic wing used by the scope for stacking might at times be over worked if the scope is also using CPU for WiFi hassling
zone thing I do to save battery is after staring a stacking session is back out to the main menu so battery use is lower not working a constant update over WiFi. You’ll still get a poo up notice of stacking failed while in the main menu. Not sure if that’s so when minimized but I do minimize a lot of times after putting that app on the main menu hoping itnn be gives the minimu batter use even while using a battery bank.
