Hi
We have a remote imaging setup and we are using an ASI2600MM PRO camera (4 years old) with last version of ZWO native driver. Since a few nights we have an issue (not always but form time to time).
We launch a sequence of images for the night and the results are good until we load a strange image with half a correct image on the upper part and black on the lower half. Then the next series of images is black. When we stretch the image we see that there is a little signal but it is very very weak...
You will find heerafter the good reaw image before issue, then the half image and the next one very weak...
we have checked power supply and USB3 and everything seem normal...we also have direct connection to EAGLE PC and short cable..
so could you analyse the issue and tell us what to do ? ...is it an hardware camera issue or driver issue or whatever?
Thanks a lot for your quick support
Brgds
Pascal
ps: 3 raw fits (1368 before issue, 1369 with half image and 1370 after issue ) are available hereafter at that google drive link : [https://drive.google.com/drive/folders/1pti0Yb95dYB-L8SLZkrIx52xoIr0Pu65?usp=sharing]
