Hello, herewith like to suggest small improvements to auto run screen. First of all there is a problem with file name in auto run screen. The name of the object is populated there from either GoTo screen if used initially to search the object or as FOV if we manually selected the object via catalog or left the name field empty. We know we can also change it manually. Problem appears when we use a previously taken photo and plate solve it to continue the project, in such cases the name of the previously taken object is not auto populated causing issue to remember to change it as if we don't, Asiair will be saving photos under the old name that was populated there previously from a previously session. Second problem is that when you enter the auto run screen you will see all the predefined sessions and the one running with the green bar indicating progress, what would come handy though is also to see the number of subs done in the real time and not only after opening the screen again. Thank You
