Thank you. But this does not answer my question. I know how to connect the imaging train together, which I have done on several rigs. The question remains that the two thumb screws for the camera and the one thumb screw to rotate the helical focuser are facing more or less towards the front and that is what I need to change as the space between the OAG-L and rotator is small due to back focus limit.
I need to rotate the top part of the OAL-L so those three screws are not facing towards the front. I have 3 OAG – L’s and the screws all face in various directions (but generally towards the front) so there is not one specific direction they come from the factory. Therefore, it tells me there is some flexibility on where they can be.
Can I disassemble the entire top part and reassemble in a way where those set screws will not be facing towards the front? Rotating 1/4 turn would suffice.
