Last Saturday I was doing the Observe the Moon night and had two live feeds running. The S50 and a Celestron 8se with a ZWO 294 camera and ASIStudio. The 8 inch feed was perfect, even with the wind. The S50 feed had a lot of anomalies in it. Most of the larger craters were so over exposed you couldn't make out details and mountains you normally wouldn't see unless they were near the terminator were popping up as white dots. I adjusted every setting I could to no avail. Is it possible to dial back the enhancement to avoid this?
